Kinetic Straps faceoff
Looking for options and opinions for a kinetic rope
Voodoo
ARB
Bubba ropes
ASR
Leaning towards voodoo 1 1/4
They are a bright color that will stand out, comes with bag, cheapest, more stretch
20ft vs 30ft
Havnt been in too many recovery situations. Can anyone give up some experiences that would help make a decision
Voodoo
ARB
Bubba ropes
ASR
20ft vs 30ft
First Kudos to you for even knowing the difference, most people don't.
You really can't go wrong with any of those brands, they all use a 12 strand synthetic fiber.
What you really need to know is what type of recoveries you want to do and the working load limit (WLL) of the strap to figure out what size you need.
Breaking strength divided by 5 will give you your WLL (Factor of 5) this is a pretty standard figure.
I'm not familiar with ASR, but for the other 3 I would say they are all the same. I have ARB because of no good reason. I would be surprised if ASR was any different than bubba, voodoo or ARB. specs are specs with pull strength/pull weight. These recovery straps have a limited use life - they can only take so many stretches, I am not sure what that number exactly is.
For length both are good. If you primarily do mountain and woods trails then shorter would be better because of the limited room to yank someone out. After you tension the strap, it will stretch as you slowly drive away to help pull the vehicle out. If you are often in open areas, esp mud bogs, then longer might be the difference between reaching and not reaching the stuck vehicle while keeping your jeep on safe ground.
Recovery straps will only stretch 3%-8% if you are lucky. Many do not have WLL or SWL ratings on them or any industry standard for testing.
Kinetic recovery ropes will stretch up to 38% and generally are tested and rated.
I would not buy anything that does not have WLL on it. Twenty feet sounds like a lot until you hook it up. I would get which one works best for you. I have a 20ft but my next will be a 30ft.
Also, bigger is not always better. You want the rope to stretch. Get one too large and you are defeating the purpose. Generally, 7/8" are the right size for JKUs (6k#).
Remember when using - crawl....walk....run.
I'm shopping for a new strap myself. My old one is 18,000 lbs 2x20'. it served me well FOR YEARS, but looking back, I should have a bigger strap.
What concerns me is that even Warn straps are made in China. How is that different from Smittybuilt stuff (which I would not buy as a strap).
I don't want to spend crazy money. Here's what I found:
Rugged Ridge 15104.01 Premium Recovery 3" x 30' - 30,000lb Capacity. Made in China: $43 on Amazon (delivered with Prime)
Warn (88913) 3" x 30' Standard Recovery Strap Rated to 21,600 pound capacity. Made in China. $58 delivered on Amazon
ARB ARB710US 3-1/8" x 30' Recovery Strap - 24000 lbs Capacity. Made in Taiwan. $82 on Amazon
Poison Spyder Recovery Strap Part Number: PSC57-63-515. 30' x 3" 24,250 lbs. minimum breaking strength. $70 on 4wd.
Smittybilt CC330 3" x 30' Recovery Strap - 30,000 lb Capacity Made in China. $37 on Amazon.
Bubba Rope 176660BLG 7/8" x 20' Breaking Strength Original Rope with Standard Blue Eye - 28600 lbs. Capacity. MADE IN USA. $160 on Amazon.
So, based on this, why not Rugged Ridge?
And is the Warn any better quality because it's Warn even though it's still made in China?
