2.5" Lift and 37's
Where do you rub? adjust your bumpstops. Has to be done regardless of lift height with those tires. I'm running those same coils you have with no bodylift and rub no where because I'm running the proper bumps, backspacing and trimmed where needed (rear seams only)
Before I cut my fenders (or shell out for a set of metal cloak) I want to make sure 37's will give a good amount of flex. I am trying for a low center of gravity build
You don't need metalcloak fenders to increase your travel. A little longer shock and some bumpstops in addition to flats- you'll be set. I put 37's on rk 2.5" stock mod and it needed serious bumpstop. It's ok for the daily driver but not for actually wheeling. It is lcg....aka cheap ass build.
2.5" Rock Krawler Long arm with 37s. Trying to squeeze 40s in there now:
https://www.jk-forum.com/forums/jk-s...ospect-289481/
It looked like 37's worked just fine with the 2.5" RK set up. I'll have to see pics when you get 40's on
This is a good thread on 37s with 2.5" of lift.
https://www.jk-forum.com/forums/jk-w...n-lift-260148/
