Bestop Lock Box Help
Picked up the Jeep Thursday and today found this mounted under the seat. No keys! Anyone know if Bestop would have keys for the box or should I just drill out the lock??
That lock is completely useless. Get a couple screwdrivers and open the box. Unbolt the lock from the inside and replace it with a better lock. I removed the entire lock and modified it to accept a slightly better lock (with a real key instead of the 'key' bestop uses).
and buy a padlock from (bolt) that will automaticly fit to your jeep key
https://www.boltlock.com/shop/gm-cen...locks/7023537/
you can order it cheaper im sure from just about anywhere but even at 20+ not a bad deal
