Thought on Fire Extinguisher mounted outside ?
Old Apr 17, 2016 | 07:16 AM
Scvette01's Avatar
Default Thought on Fire Extinguisher mounted outside ?
I have a aftermarket swing tire carrier, also has a 4 container Rotopax carrier attached to it. Plenty of mounting options for a 2.5lb extinguisher (already have)
What thoughts of it sitting out in the elements?
Jeep is garaged
Not a DD
Do take it on 3000 mile trips once a year
If mounted, it'd be on driver side, between the carrier and swing gate
Old Apr 17, 2016 | 07:27 AM
Jonathan_JK's Avatar
I'm going to do one on the tailgate as well. I'm going to draw up some plans and probably make the mount myself.
Old Apr 17, 2016 | 11:26 PM
carlojp's Avatar
It depends on the quality/type of fire extinguisher. Extinguishers with metal valves won't leak , unlike plastic valves that has a tendency to leak due to temperature changes.
Old Apr 18, 2016 | 03:04 PM
Vladimer's Avatar
I would be semi worried about theft. You can't lock it or make it more then a single step to unfasten or else thats a big problem in an emergency when someones adrenaline is running and they are fumbling with some attachment device you thought would work well.
I mount mine on the sports bar so its only open to the elements in the summer. Had it stolen while parking in downtown along with some other stuff. Found a homeless guy wearing my windbreaker and fleece that was stolen at the same time about a block away. Got that back but never did find the fire extinguisher.
