Run with no fender liners in front after flare trimming?
Poison Spyder just came out with some new front fender liners that look pretty sharp. Saw them at Moab and I'm really close to pulling the trigger. My only problem is getting them to clear my suspension, and there would be lots of trimming required to get it to happen. Lots of people run without, but these look good enough to run with, and they seem like they're designed to clear when crawling as they had them on some pretty stout looking rigs at the vendor show.
I Run the Fronts but the rears are off. If you don't run the Fronts your going to get way more crap in your engine bay than if you ran trimmed OEM liners
* Edit* I did have to cut a hole in mine to get my Snorkel to clear. Here are some pictures with and without liners
Probably just depends on your local conditions and use.
I trimmed the front liners, but kept them in. (pulled the rear liners and sprayed with bedliner.) Onroad, I didn't want all the slushy snow and ice and junk getting thrown into the engine bay from the tires. Offroad, same thing with mud and whatever.
