can i trust shops
It's really important that the shop torque down the control arms, track bars, etc after the lift is fully installed and the vehicle weight is fully on the tires (with all of those parts still loose and unbound). Shakes, shimmies and even death wobble can occur if not done that way. Yet, for many shops that means the mechanic is crawling around under your vehicle on the ground. If they don't have a pit, or a lift that raises the vehicle by the tires (not the frame), ask how they will torque all of that down. If they argue that it isn't necessary to torque all of it as I've described, find another shop.
Lots of good shops out there. Keep in mind that they are only as good as their weakest tech. The question is who will actually be doing the work and do you trust that employee? When there is an issue, it is usually related to attention to detail or the desire to take the time to do it right (such as lowering the Jeep and then torquing bolts). Small things like using a paint marker after torquing a bolt would be things to look for. Even the best tech can miss something on accident, so those types of tricks prevent them from missing something.
On the flip side, we've seen control arms mounted on the wrong side, track bars upside down, and the list goes on. Every vehicle is different. Finding a shop that specializes in Jeeps and JKs would be the best bet.
That all said, doing it yourself is the only sure way to know it is done right.
Not that doing it yourself necessarily means it's done right. I'm sure that most of us can remember a few mistakes we have made with various lifts and mods. But, even doing it wrong can be a great step in the 'learning experience' for owning and working on our jeeps.
I have never had any issues with using a shop for anything, most shops back their work. I just did my own lift and I am glad that I did because like most people are saying, I ran into some snags and had to do some research, but I learned so much more about the jeep while doing so.
