Wanted Make it easier for people to clean out their garage by letting them know you want their dust collectors. Post the things you want and/or are looking for here.
OE Rear Sway Bar Links
Old 03-22-2008, 05:42 PM
cjsdad's Avatar
Default OE Rear Sway Bar Links
I am looking for a pair of rear sway bar links. I have the TF 2.5 BB with the OME shocks. The rear links I got from TF are too long. I have some rub on the sway bar with the tire, but bigger issue I noticed today is that the link/sway bar are bend my rear brake line. Not good. I want to try the OE links to lower the sway bar. Thanks in advance.
cjsdad is offline
Old 03-24-2008, 04:37 AM
MAROONJEEP's Avatar
bump for a good guy
MAROONJEEP is offline
Old 03-27-2008, 01:15 PM
cjsdad's Avatar
Originally Posted by MAROONJEEP
bump for a good guy
Thx for the bump
cjsdad is offline
Old 03-31-2008, 08:41 AM
jonsjeep's Avatar
I have a set of OEM rears and a set of Skyjacker rears. I had the SJ on my 4dr when i had my 2.5bb and they worked perfectly. pm me if your are interested.
jonsjeep is offline
Old 04-06-2008, 09:16 AM
Ken Jong Il's Avatar
PM if you still need the rear OE links
Ken Jong Il is offline
Old 04-06-2008, 12:19 PM
FunN4Lo's Avatar
If nothing works out with the other guys let me know. I've got a stock set laying around.
FunN4Lo is offline
Old 04-08-2008, 10:56 AM
Big Clint's Avatar
I've also got a set if still needed.
What issue are you having? I have the same BB and no issue. I remember putting on the brake line extension bracket and it could go on either way...meaning you may just have in on backwards and need to flip it over. I don't recall if it would have produced any rubbing if on backwards though.
And on the rubbing on the tire...you will have rubbing on the rim/tire with the OEM wheels if you don't put on spacers. The clearance is minimal on both sides. Before I got my spacers (before later replacing my wheels/tires) I had the 18" Sahara wheels and the drivers' side was rubbing the inside lip of the wheel on bolt head attaching the link to the sway bar. Spacers or wheels with different backspacing cure this.
Big Clint is offline
Quick Reply: OE Rear Sway Bar Links
