Outside window A piller bolt size
Old May 4, 2016 | 05:58 PM
MacRubi2's Avatar
Default Outside window A piller bolt size
Hey guys does anybody know what size those 6 black bolts are? Thought they were a SAE since metric ones didn't match up but even the SAE ones still didn't thread properly.
I was going to install a light bar and the brackets that I have I would like to have a little longer ones so anyone know what they are?
Thanks
Old May 6, 2016 | 12:17 PM
MacRubi2's Avatar
Anyone 🤔
Old May 6, 2016 | 12:38 PM
NJKURPat's Avatar
I would just call the mopar parts department or go to the dealer and have them give you the specs. They probably have some bolts on hand that are a little over priced, or you can find them once you get the specs.
Old May 9, 2016 | 01:26 PM
MacRubi2's Avatar
Yeah probably what I will what I will have to do
I'm getting the fealing that when you buy a cheap set of 50" LED light bar brackets they aren't going to fit flush against the A piller like it should
Anyone have the same issue with a cheap pair of brackets and did a more expensive ones like Riged or TF ones fit better
Old May 9, 2016 | 05:57 PM
kevinlee's Avatar
Take a bolt out and goto your local autozone they have a card with a bunch of threaded holes find the one that it fits and that's your size.
Old May 10, 2016 | 09:16 AM
Jonathan_JK's Avatar
Is the head a torx 50? I would go to the Jeep dealer get the specs then go on Amazon a order them. The fastenal here is a joke they have to order most stuff because they have very little on hand at their store. Which makes no sense to me.
Old May 10, 2016 | 12:06 PM
John_fender's Avatar
They are metric M8 1.25m 25mm. I have used a stainless button head bolt with
a 30mm length when I mounted my pillar lights.
Old May 10, 2016 | 01:13 PM
MacRubi2's Avatar
Did that already but when I tried to thread the new bolts in they seemed to start too cross thread
The oem ones matched up to a sae thread but not so much in the Jeep
Old May 10, 2016 | 01:16 PM
MacRubi2's Avatar
Awsome John_fender that's the answer I was looking for 😎
Thanks
Old Jun 21, 2024 | 08:50 AM
Cubulco@1971's Avatar
Thank you, I got a set of mirrors when I take my doors off or when I use the tube doors. I also got a light bar and its bracket, the bolts that came with the mirrors are shorter than the OEM, but the OEM have a fatter head. I got a set of allen-drive Cap bolts (M8x1.25x30) at Lowe's and they are perfect. Thanks for the info
