What Rear Axles???
Old May 5, 2016 | 06:20 PM
devwil68's Avatar
Default What Rear Axles???
So I believe I have a bent rear flange and am looking to replace my rear shafts.
I'm running a 2013 sport. These
I have read that some have better warranties, some come pre-pressed...
What is the best option for shafts and how many splines do I go with in everyone's opinion?
Thx in advance!!!
Old May 5, 2016 | 06:22 PM
Chuck-The-Ripper's Avatar
Ten factory
Old May 5, 2016 | 06:26 PM
ShutterBug's Avatar
^^^^ This. Guaranteed for life.
Old May 5, 2016 | 06:38 PM
urmyboyblue's Avatar
Veteran: Navy
I can only see 10 year warranty. Maybe I'm missing it. But to throw another option, my Alloy USA axles were a bit less and 10 year warranty.
Old May 5, 2016 | 06:59 PM
devwil68's Avatar
Haven't had much luck finding Ten Factory pre-pressed.
You guys have a part number that I might be able to use?
Old May 5, 2016 | 07:05 PM
mcochrun13's Avatar
Originally Posted by devwil68
Haven't had much luck finding Ten Factory pre-pressed. You guys have a part number that I might be able to use?
Contact Northridge4x4 on here, they will hook you up. I just got mine a couple weeks ago.
Old May 5, 2016 | 07:07 PM
wittys-jk's Avatar
Call Northridge they will help you with exactly what you need for your current set up. I'm running 10's myself
Old May 5, 2016 | 07:14 PM
NJKURPat's Avatar
I'm running ECGS they came bearings pressed and shipped for $415. If I wasn't under a time constraint, I would have called NR4x4 to see what pricing was on Ten Factory, but time was crucial and ECGS had them to be in under 48 hours.
Old May 5, 2016 | 07:19 PM
Albino Lizard's Avatar
I'm running ten factory from northridge. They are great. Not one problem.
I thought my flange was bent when I bought them. Turns out it was an axle bearing. I saved the factory axles and will rebuild at my leisure. Bearings are pretty cheap. I'd try that first. The sign of a bearing problem is squeaking. I was told that one advantage to moving to a full float axle on the rear was much stronger bearings.
Old May 6, 2016 | 04:20 AM
larry0071's Avatar
I also just did the 10 factory and had NorthRidge 4x4 press on new tone rings and bearings before shipping. Talk about an easy way to go!
