Synergy front sway bar links. Anyone make there own quick disconect set up?
Old May 7, 2016 | 10:05 AM
Learo2000GT's Avatar
Default Synergy front sway bar links. Anyone make there own quick disconect set up?
Good afternoon.
I picked up some synergy from sway bar links on Craig's list. I was looking at making my own quick disconnect setup with wing nuts and pins or something and was wondering if anyone has done this? Thanks in advance.
Old May 7, 2016 | 10:55 AM
jchappies's Avatar
yes i have
go get a 1/2in 3in grade 8 bolt, cut the head off and drill a hole for a pin and bolt it up
Old May 7, 2016 | 11:26 AM
Originally Posted by jchappies
yes i have go get a 1/2in 3in grade 8 bolt, cut the head off and drill a hole for a pin and bolt it up <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=646384"/>
Perfect thanks bro. That's what I was thinking but I have learned to use others success instead of attempting my own failure. Hahaha.
Old May 7, 2016 | 11:27 AM
Do you put plastic washers on each side then regular washers? Thanks again
Old May 7, 2016 | 11:29 AM
jchappies's Avatar
No i'm just using the plastic one against the heim, but either would work.
