Steel beadlock wheel
Old May 12, 2016 | 04:27 AM
Guascone's Avatar
Default Steel beadlock wheel
Hi guys, I'm searching some pictures about jku with steel beadlock wheel...
If you have it could you tell me also their offset?
Thanks a lo!
Old May 12, 2016 | 05:17 AM
Maertz's Avatar
Thanks a lo!
?df7b?df7b?df7b
I did a weld on kit. You can put them on any steel wheel typically. Mine are 3.5 bs and rim and bead locks combined i bet were around 600
ID:	646801   Click image for larger version
Old May 12, 2016 | 05:30 AM
Guascone's Avatar
Thanks for your pictures!
Here in Italy I have found d'auto a beadlock wheels with offset 10...
I'm afraid about their look on the jku due to the small offset...
What do you think about it?
Old May 12, 2016 | 07:21 AM
TheDirtman's Avatar
Looks like too much back spacing to me. I don't see how they are 10mm offset. What is the width of the wheel?
Old May 12, 2016 | 07:36 AM
Guascone's Avatar
The width is 8 inches...unfortunately I don't know the backspace.
Old May 12, 2016 | 07:44 AM
TheDirtman's Avatar
From the looks of it I would say around a 6" back space. Basically the same as the stock wheel. Plan on adapters for anything wider then stock tires.
Old May 12, 2016 | 11:11 AM
Guascone's Avatar
Thanks, for the answare. The wheels should have the same charatteristic in terms of back space, offset and width as rhe AEV pintler...
I'm still not conviced abou the look ok the jku...
