Wheel spacer question?
Old May 13, 2016 | 05:22 PM
MrR1ght's Avatar
Default Wheel spacer question?
I am sure someone has covered this somewhere but I have yet to find what I am looking for. I am ordering the AEV 2" spacer lift. Planning on running the MT Deegan's 285/75R16. AEV says I can run 33's. To the heart of the question what do I need for spacers if any. I am going to run stock rims. It's a 2016 JKU Black Bear. I want to go with the least spacing possible. But don't want rubbing.
Old May 13, 2016 | 05:31 PM
nthinuf's Avatar
The spidertrax type adapters, with two sets of bolts. Not the thin ones that sandwich in between. Most choose 1.5". Teraflex makes a 1.25", but you may need to grind down the studs to run them.
With that size tire, you might even be ok without the adapters. Or with a washer or two on the steer stops. Too many variables to say if they'll rub, so yeah, the adapters are probably a good call.
Old May 13, 2016 | 05:57 PM
MrR1ght's Avatar
Thank you nthinuf!
