Bad Gear Install? Opinions Needed
So I had my axles regeared to 5.13, did the break-in and changed the fluids at 500 miles, at 4000 after the install, this happened to the d30 front. I cant tell if the carrier cracked first, causing a spider gear to break in half completely, or if a tooth was chipped, that fell into the spider gears, causing one to break in half, and crack the carrier housing. Any input is appreciated
So need a carrier with spider gears to hold the inner end of the axle shaft. I would have concern for the bearings though as well, due to the damage, probably have metal shavings in the bearings.
Short answer is no. The axle shafts are required to hold the unit bearing (wheel bearing) together. Could split the shafts and just use the outer stub, but probably more work than its worth. Housing would not be sealed anymore either.
I stand corrected. I was unaware that the JK unit bearings were capable of this. I was always thought unit bearing required the support of a axles shaft to prevent them from splitting, seen it happen first hand. Here is a link to a article referencing this information on how the JK bearing is different; Jeep Wrangler Unit Bearings: What You Don't Know Can Hurt You | DrivingLine
Learned something new.
Interesting. From the photos it looks like the spider gear might have gone first, cracked the carrier, and then the broken parts probably took out the teeth on the ring and pinion.
From what I can see the wear pattern on the ring and pinion doesn't look too bad, so it wasn't setup badly.
What were you doing when it went?
