Most commonly used trail tools?
What's your most commonly used tool on the trail?
After decades of "off-roading" I've found the Hi-Lift jack is easily the least used...
Most used:
SAW - by far and away, particularly early in the season
Recovery strap - so easy to just give a little tug...
Max Trax - the past year or so we/I started using these things and wow... They really make life simple...
I have a decent winch, but, some years it doesn't get used at all. The saw though... Those puppies are often in use!
Max Trax in action:
Winch and saw used here:
This is up in the Pacific Northwest, where trees abound, and often fall, blocking the way. When I used to wheel in the southern California desert, 25+ years ago, I'm not sure I ever used a saw except for cutting firewood...
Thanks!
Most used:
Max Trax in action:
Thanks!
I found that most small cross cut saws jammed up in wet wood. I bought a small lithium battery powered chain saw. It chews right through wood that had my hands bleeding before. Not as compact as a folding camp saw...but at least I can get to where I need to. I carry a short recovery strap. I used to carry a much longer higher load strap but the short one is more convenient. I also carry a military surplus folding shovel...great for digging out snow, piling small rocks as a ramp, making a rain trough around a tent, and burying you-know-what.
I've done a lot of solo wheeling, and for a while I didn't have a winch, so my hi-lift jack got a ton of use.
- Pick up the Jeep to stack rocks/logs under tire
- Winch out (very slowly, but it gets the job done)
- Straightening bent steering components
- Handle is great for turning a little ratchet into a huge breaker bar
Gloves for less-busted knuckles
A good size hammer is always useful
