Coil spacer recommendations...
Old Oct 19, 2016 | 08:56 AM
orp967's Avatar
Default Coil spacer recommendations...
Hey fellas,
Just wondering if anyone could recommend some good, high quality yet affordable coil spacers.
I need 1.5" spacers for the front and 2" spacers for the rear to level my Jeep out. Prefer spacers from the same company if possible.
I have an 09 JK 2-door if it makes a difference.
Thanks
Old Oct 21, 2016 | 04:54 PM
Kempo x Ted's Avatar
Default Leval
I put a quadratec 1.75 kit on mine and was perfect and at 120.00 you can't beat it and only had to adjust the drag link half turn.
Old Oct 21, 2016 | 05:18 PM
nosnhoj1's Avatar
Is your rear .5" lower than the front as it sits now? Do you already have any kind of lift on it already?
Old Oct 21, 2016 | 05:57 PM
Biginboca's Avatar
I can steer you away from some really crappy ones. Don't buy teraflex! I had 2 of their spacers disintegrate on my rig and I've seen this same issue posted by others. Their spacers are made of water soluble cheese whiz or something
Old Oct 21, 2016 | 09:02 PM
ShawnNoble's Avatar
I had good luck with procomp spacers on my 09 JK.
Old Oct 22, 2016 | 04:38 AM
phljeeper's Avatar
Originally Posted by orp967
Hey fellas, Just wondering if anyone could recommend some good, high quality yet affordable coil spacers. I need 1.5" spacers for the front and 2" spacers for the rear to level my Jeep out. Prefer spacers from the same company if possible. I have an 09 JK 2-door if it makes a difference. Thanks
Typically you want the reverse of that. The front usually gets a half inch to an inch more to level out.
Old Nov 3, 2016 | 09:37 AM
zzodo's Avatar
So far I'm having good luck with my Rough Country spacers. They are metal.
Old Nov 3, 2016 | 10:06 AM
ArmyofMike's Avatar
OP, I think you are backwards on measurements. I think you want 2" in front and 1.75" in rear to level.
I went with the Rough Country Steel Spacer lift. I got 2.5" up front and 1.75" in rear which did level my jeep out nicely. I have been VERY happy with this lift and install was easy peasy. I had to take the front spacers out last weekend to install TF Bump Stop extenders in the front (I highly recommend doing it when you install the lift in the first place, I skipped and the rid and "slam down" of the front was terrible) and when I took the front RC steel spacers out, they looked brand new.
The ride quality stayed close to stock, but I got a much needed lift to fit my 35's.
The price on the RC is very affordable, and this is one time where I bought a lower priced item and am happy with the product and outcome.
Old Nov 5, 2016 | 08:50 AM
CJ7nvrstk's Avatar
Vet Army
Rough Country worked fine for me when I ran them. My stock springs started sagging badly though so I ended up having to put new springs.
