Sway-bar quick disconnect lengths
Quick question, a local shop installed the artec truss kit on my front axle and now one of my quick disconnects is longer than the other as the mounting point height axle side is higher due to the truss. Is this an issue?
Maybe I'm missing something, but the artec truss has no bearing on the sway bar link tabs; unless they also installed a new track bar bracket as well. If so, just adjust one side shorter. It will have no bearing on alignment or drive ability as would other things.
In simpler terms, No. it will have no negative side effects.
Maybe I'm missing something, but the artec truss has no bearing on the sway bar link tabs; unless they also installed a new track bar bracket as well. If so, just adjust one side shorter. It will have no bearing on alignment or drive ability as would other things. In simpler terms, No. it will have no negative side effects.
