Axle shaft spline count
I have an 08 unlimited x and have a chance to pick up a Eaton e-locker for 200 brand new in the box. It says it's for 30 spline shafts. Dana 44. Are stock axles 30 spline ? Also mine has factory limited slip.
Coolbeans, looks like I'll be locking my rear diff. I was prayin it was because shortly I'm gonna regear and I'm gonna put A Yukon zip locker in front and now for only a small price gonna lock rear too. So one will be air and one electric
The Rubi front D44 is also 30 spline.
Jeff's point was to see if the part was for a front or rear. The rubi 44's are dimensionally different inside the differential so even though it's 30 spline and for a 44, it may not fit. Be sure to check with your seller.
Dang thats a Deal I spent $800 on mine. I wish I could have gotten that deal. You know if its the old 2 pin type or the new 4 pin type. This makes a big deal in strength.. I know a lot of venders were trying to unload the 2 pin E lockers for cheap. So Just beware, either way its still a deal.
