07 2dr auto w/ 2.5" lift, Do I need to replace front and/or rear driveshaft?
Hello, i'm ready to pull the trigger and get a 2.5" lift. I've seen mixed thoughts regarding the driveshafts. Some say no problem while others say replace the front drive shaft. However, I was looking at the installation instructions for a superlift 2.5" kit and they suggest replacing only the rear driveshaft. I'm very confused. Anyone with experience or input?
After the lift is installed, flex it and check the clearances. Then, as part of normal maintenance, you should be crawling underneath and putting an eyeball on those joints. When you see a ring of grease above a joint on the undercarriage, you'll know its time.
TJs used to require a replacement rear shaft on most lift kits just because it was so short. I haven't heard of a reason to replace the rear unless you get into tall lifts with extended control arms. The front shaft will probably touch the exhaust crossover which is why most companies will recommend either a more narrow drive shaft or to install an exhaust spacer. I have spacers and they were the cheaper option but it does drop down below the crossmember by a few mm.
