Rough Country trackbar joint part number?
Tracked my death wobble down to my front trackbar. Egg shaped bolt hole on frame end with slack in between the bushing and the end. I've sourced the bushing for the upper side but now I need the heim joint on the axle side. Leaving for a trip in 2 days and need this piece to get back on the road. Does anyone know if I can go to O'reilly's, Napa or Autozone and get this piece? Unfortunately I need it bolted in to get to the parts store so I can't really walk in with it and compare it against their stock. I've found a few threads with links to moog and rockauto websites but the links are bad and they don't list the actual part number that I need. Any help is appreciated!
Axle side: 3/4" shank, 3/4" hole, 3/4x16- right thread pitch.
Frame side: RE1685 rubicon express part number. Had to use the bushing from my original joint.
Worked great, zero slop. Drilled out frame side mount and installed 1/2" grade 8 hardware.
