Synergy sector shaft brace with teraflex
I'd only clarify that the sector shaft brace will not work. The track bar brace itself will, but the TB will hit the big bolt on the sector shaft brace if that is added. I'd also point out that even if you are running the synergy TB with that sector shaft brace, odds are high that your driver's side front spring will rub on the mount as well unless you're running Synergy's springs. See a pattern here?
I ran the sector shaft brace for a while, but I moved from Synergy's TB to Rock Krawler's, and at that time I made the decision knowing the SS brace would need to come off. Other's might disagree, but I'll go so far as saying that if you're going to wheel so hard you're worried about bending the sector shaft brace, it's just better to think about some hydro assist steering. I wheel my jeep pretty hard, and am right on that cusp of going hydro, but I really don't think anything I've put my jeep through up till now was make or break as far as that SS brace saving me from damaging the shaft. That said, definitely reinforce that frame side TB mount.
Interesting. I run 3.5" RK coils with Metalcloak arms setting my caster. They rubbed on my sector shaft brace. I also rubbed on some 4" Pro Comp coils previously. Might be a little dependent on the shocks you run and flex you achieve, but Synergy will definitely admit many non-Synergy coils will rub on that brace.
You and I had this discussion already in another thread. My sector shaft brace rubbed my synergy springs with stock control arms until I chopped and welded the brace. That probably rings a bell for you now that I mention it again, lol
