Geometry control brackets
Old Nov 25, 2016 | 06:23 AM
Nassd89's Avatar
Default Geometry control brackets
Hey everyone! I came across some geometry control brackets by Metal Cloak that bolt on to the existing brackets for short arm lifts. I didn't know these exist. So I currently have a 4.5" BDS lift and was wondering if any of these brackets would work? is there any other parts/modifications I would need to make along with these and would it give me extra height since they drop 2" down?
Thanks!
Old Nov 25, 2016 | 06:28 AM
TheDirtman's Avatar
Brackets don't give you height, they correct geometry. They should work with your current lift if you are using factory control arms. If you are using longer fixed arms you will get too much caster. If using with adjustable control arms make sure before hand that they can be set to factory length
