RK Offroad Pro Long Arm Length vs Other Brands
Thinking I'm going to get the RK Offroad Pro long arm for my JKU. I just have a question about the front lower and possibly upper arm lengths.
From looking at pictures, the arms almost look like a regular mid arm length. When I see pictures of say, Teraflex long arm equipped JKU's, they seem way way longer.
On the other hand, the TF upper arms are very short for a long arm system, especially in the rear. This is why I don't want teraflex. I get 10% off RK parts and their warranty and customer service are off the charts.
Does anyone run the RK off-road pro long arm on a jku? I have a hard time finding any pictures of this system on anyone's rigs on forums.
Anybody know why their front arms seem so short for a long arm system? Am I just crazy? If Rock Krawler has anything to say I'd be glad to hear it.
Probably because the stock arms are pretty damn long. Extending them a foot makes them 3' which is pretty long, at least I think so.
Longer in the rear seems very appealing but depends on your use.
You're the dude running 37s with no lift right?
Still no lift planned even with long arms? Or maybe jus a lil bit?
Probably because the stock arms are pretty damn long. Extending them a foot makes them 3' which is pretty long, at least I think so. Longer in the rear seems very appealing but depends on your use. You're the dude running 37s with no lift right? Still no lift planned even with long arms? Or maybe jus a lil bit?
Not trying to be an ass but that reply on the arms leaves a lot to be desired....I'll say it that way. Look at any long arm kit and especially custom made arms and they're all very long. There's a reason behind the design of a long arm. The stock arms are not that long like you act. Yes they're much longer than previous jeep models and that's because the jk it bigger as a whole. But they are still "short" arms despite being closer to "mid" arm length than other jeep models. The angle at which mine sit and the way they perform and feel even at 2.5 sucked and especially now that it's at 4" it sucks big time. Pinion angles screwed. Want better on road feel that comes with long arm at this height. So I'm asking about the reason behind the apparently short length of this particular long arm. I want the pro kit due to the high strength and light weight aluminum construction. And the joints are greasable.
Perfectly understand, reading it back now I think you got my point. As terribly as I interpreted it, the arms on jk models are longer when compared to others.
That is one sweet looking jeep. Two thumbs up!
Does it still come raw or is it black like the rest of RK stuff?
Also, I've got front and rear Currie Antirocks on the way, how do you think it will ride with the 3-links and antirocks? Too much body movement for DD? Or pretty much the same until I'm really articulating off-road?
Can you post some shots of the arms from the side of the jeep?
I modded the front lower frame brackets so I could fully flex the 11" shocks. My ride height is 5"
Side-hills great, street manors are better than stock.
I have a Currie 1" rear and a ORO front sway bar.
Weigh's 6400 lbs as it sits.
In the process of doing my LS-6l80e swap.
C/O-Bypass all 4 corners , keeping the front 3 link but will go to a double tringulated 4 link in the rear.
