JK Front Wheel Hub/Bearing
Getting ready to replace both hub assemblies, is there any hub I should stay away from or what is the preferred hub when replacing? Driveworks $111.99, Moog $140.99, Timken $157.92?
Or other recommendations?
A few years ago, they were all made by Iljin, no matter what it said on the box.
Could have changed since then, but I doubt it.
Look at one in the parts store. See if it says Iljin somewhere on the back of the flange.
I just bought mine a couple months back and went Timken because of the competitive pricing over taking a chance with the DriveWorks.
It was either Amazon or Rock Auto that had the lowest price when I was buying.
The 07-10 will be the same bearing but have a shorter ABS lead than the newer models. Routing the wire a notch up from the factory setting prevents issues of it being too short for the lift.
I just bought mine a couple months back and went Timken because of the competitive pricing over taking a chance with the DriveWorks. It was either Amazon or Rock Auto that had the lowest price when I was buying. The 07-10 will be the same bearing but have a shorter ABS lead than the newer models. Routing the wire a notch up from the factory setting prevents issues of it being too short for the lift.
It won't be shorter than what you've currently got on the vehicle unless they've been previously replaced with the newer style (I had one that I 'upgraded').
I'll grab pictures in the morning but if you skip the first hard mounting point at the bj and take the rubber piece (that would normally go there) straight to what would be the second hard mounting point you'll have enough clearance. I'm also running 2.5" with the 07-10 leads and haven't polled a line out yet.
Your box is full.
Yes, if it was just regeared then they definitely pulled the shafts out so the hub should come out pretty easily. It's tough to tell if they pulled the hub and shaft as a single assembly or if they pulled them separately- it cuts down on labor if they can pull it together. Before you start your water pump you can get the axle nut off and spray your penetrating oil down on the splines just to be sure.
Put the socket on the frontmost hub nut and turn your wheel hard passenger, it should give you a good bump towards getting it out.
Whose 2.5" do you have? It doesn't look like you'll have an issue with needing longer ABS lines or modifying like I've done.
I'm up to head over if it still isn't off in the morning.
