Gear Lever "Recall"
Old Feb 20, 2017 | 10:58 AM
mr72's Avatar
Default Gear Lever "Recall"
Today the local Jeep dealer did the "Recall" (not really) on my '15 Wrangler's manual transmission gear lever:
https://www.chrysler.com/universal/w...ce/pdf/S60.pdf
The result? Gear engagement is remarkably more solid and sure. The pattern is dramatically tighter. No more hunting for 6th gear. And I get the impression that the throws are shorter, but I think it's most likely because there's so much less "slack" in the linkage.
My Jeep has about 20K miles and the gear lever engagement has not degraded or changed since new. I test-drove several others with the same 6-speed manual and the feel was identical with all of them. Clearly the "recall" does something meaningful and is not what I would have expected just for a rubber spacer replacement.
Old Feb 20, 2017 | 01:37 PM
afpilot82's Avatar
JK-Forum Ambassador
Thanks for the post, might have to give my dealer a shout this week.
Old Feb 20, 2017 | 05:32 PM
Kellen's Avatar
Did they send you something because it feels like I have those problems.
Old Feb 21, 2017 | 08:38 AM
mr72's Avatar
Yes, I got the "customer satisfaction" notice in the mail.
Sounds like it was only certain 2015 and 2016 manual transmission JKs that had this issue, they seem to be build-date limited. Not surprising that all of the ones I test drove had it since they were late 2015 builds just before the 2016s came out.
I suppose if you didn't get the notice, there's nothing to fix.
But man, is it ever night and day different.
Old Feb 21, 2017 | 02:01 PM
Four Low's Avatar
I'll look into this, my 2015 (build date March 2015) has less than stellar shifting. Im used to it, but would like Improvement !
Old Feb 22, 2017 | 08:08 AM
mr72's Avatar
If you didn't get the letter, my guess is you will not be covered.
