Rampage Trailview Soft Top (JK 2 Door)
Old Mar 7, 2017 | 06:21 AM
RnR's Avatar
RnR
Default Rampage Trailview Soft Top (JK 2 Door)
I installed this top on my 2016 JK this past weekend. It's an easy install however the instructions are a bit confusing. The door surrounds are not pre built like other frameless tops and the screws are not pre-drilled into the plastic end pieces of the door surrounds. I used a small drill bit to create a hole which made the assembly much easier. There is a youtube video put up by rampage showing step by step how to install. WATCH that video in conjunction with the instructions. The video is for a JKU so JK owners will have to improvise certain steps.
Note - The Green packaging is for the drivers side and the white is for the passenger side. I noticed this after opening both packages.
There are two nice features with this top.
1. The front folds back giving an open air experience for the driver and front passenger. There is a built in frame for this feature that makes it very easy to operate. You can do it while sitting at a red light, it's that easy.
2. There is an extra layer of canvas in the back that allows you to store the side and rear windows so your not stuck either leaving them at home or shoving in the backseat area. It also comes with a nice case to protect the windows from scratching that's kept inside the 2 layer back portion of the top.
I will post pictures up later of features 1 and 2 if anyone is interested. There are pics and videos out for the JKU, nothing for the JK. Why I thought I would share.
Name:	Jeep 3-5-16.jpg
ID:	667833   Click image for larger version
ID:	667835   Click image for larger version
Old May 21, 2021 | 09:20 AM
Beaglescout10's Avatar
hi,
Im considering one of these tops for my '17 JK.
wondering if you have pictures of the other features . there seems to be none of a twodoor jeep out there.
thanks
