2017 Radio Questions and possible upgrades
Ok, so I just decided to trade in my 2014 Sahara for a 17 Sahara,
My 2014 had the radio (no Nav) with uconnect and the subwoofer mount at the base of the passenger roll cage in the trunk as everyone knows
the 2017 radio (no nav) placed the sub in the storage tray in the trunk (I believe the 15s and 16s did the same) so I opted to go with the radio (no nav) without the sub but still has the uconnect, due to wanting and needed the storage area for trailer stuff and storage.
Radio model on 2017: Radio 130 with Uconnect and Satellite with 8 Speaker system
so here is my dilemma
so here is my dilemma - radio at low and mid volume is great, I put it up and then there is little base an the speakers bottom out and sounds terrible so I need to upgrade it but want to keep it OEM, there is zero bass.
I do not have room for a under the seat sub due to seats constantly moving and unsure if I can hook up one to this radio head anyways
here are my questions:
1 - If I just change the head units will that provide more amperage to the speakers?
- if so what faces can I put in? years of radio's and models - should be compatible with 07-17 I believe
2- do I have to upgrade the speakers as well or will just upgrading the speakers be enough to get clear volume and bass at a higher volume limit
3-can I add the radio with the 8 inch Nav Screen and what years would be compatible and would this provide enough to increase bass and volume? (honestly want to put this head unit in it anyways.
I am handy and have done stuff like this in the past, so technical not a problem
thanks guys, looking forward to answers and recommendations
so here is my dilemma - radio at low and mid volume is great, I put it up and then there is little base an the speakers bottom out, terrible distortion, terrible bass, and sounds terrible.
I need to upgrade it but want to keep it OEM.
I do not have room for a under the seat sub due to seats constantly moving the seats and using under the front seats for storage and unsure if I can hook up one to this radio head anyways
1- can I just add a OEM app?
2 - Can I just add in a OEM amp - plug and play?
3 - Can I just change the head units will that provide more amperage to the speakers?
4 - do I have to upgrade the speakers as well or will just upgrading the speakers be enough to get clear volume and bass at a higher volume limit
5 - can I add the radio with the 8 inch Nav Screen and what years would be compatible and would this provide enough to increase bass and volume? (honestly want to put this head unit in it anyways.
