2011 JKU softtop fit on 2017 JKU?
As long as you get all the hardware and windows, yes it will fit. There have been small design changes over the years that could result in miss-matching parts from different years. The safest is always to make sure you get all the hardware and windows and it will fit.
It's the same, but you'll find the newer tops are going to be much nicer. As long as you have the corresponding hardware (door surrounds, mounting bracket, etc) you can put any soft top on there.
