Jeep jk psc ram hose routing
There are going to be variables from Jeep to Jeep, lift to lift, in regards to routing, brackets, etc, so I don't know that there is a one size fits all answer to your question. The key is to have it run where there is no potential for it to get pinched between two points, or caught up by rocks or branches from underneath, or otherwise damaged when you're off the pavement, or even on. Helpful, right?
Sorry for the delay. I checked and my lines run off the end of the ram, loop around the trackbar mount, run up the bottom until about the halfway point and then begin to turn back and up and are at about halfway between being horizontal and vertical by the time they reach the pumpkin and finish up top.
They are pressure lines so there isn't a right or wrong way to route them as long as they're not at risk of being compromised.
