Can I put 35's on with out lifting it first?
Old Nov 5, 2017 | 04:12 PM
popeyepalmer's Avatar
Default Can I put 35's on with out lifting it first?
I wanted to purchase some 35's and put on some 17 inch rims with 4.75 backspacing. Can I do this to stock (NO LIFT YET) non rubi 2017 JKU sport. Will I need to replace fenders?
Old Nov 6, 2017 | 06:10 AM
TheDirtman's Avatar
Yes you can, with 4.75" bs you may have some slight rubbing at the extremes. 4"-4.5" on a 8.5"-9" wheel is recommended. A 3/4" front coil spacer and flat fenders is a good option to lifting as well if you are not out rock crawling as it keeps the steering and geometry factory for a good on road ride.
