JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
trail PSI
Old Jan 27, 2018 | 06:16 PM
lowendrider's Avatar
Default trail PSI
I've got a fairly heavy 2 door with 285 70 17 BFG KO2s, load range E. They are mounted on factory wheels. The question is, how low would you go on air pressure for general trail riding? I had Duratracs before with a C load range and ran around 15 psi, these Es are stiff though and I'm not sure they'd give much at that psi. Any thoughts?
Old Jan 28, 2018 | 05:01 PM
jadmt's Avatar
JK-Forum Ambassador
12-15psi is where I run my e rated in stock rims.
Old Jan 29, 2018 | 06:22 AM
BlueBaby's Avatar
I run 12 most of the time on E rated 37s on 8.5" x 17". Sometimes as low as 8, never an issue.
