March Madness Air Compressor Sale!!!
All On-Board & Portable Air Compressor systems are on sale for the month of March!
VIAIR 300P Portable Compressor ( 33" Tires):
300P is a larger powerful portable tire inflator kit that is capable of inflating up to 33-inch tires easily by simply clamping the power leads to your battery, connecting the tire chuck to the valve stem and turning the unit on. Tire pressure can be checked using the 5-in-1 Inflator/Deflator inline pressure gauge.
Click Below for Pricing!
https://www.lge-ctsmotorsports.com/s...%20compressors
VIAIR 400P Portable Compressor (35" Tires)
400P Portable Compressor kit offers inflation of up to 35" tires operating up to 150psi for 15 continuous minutes at a time. The 400P is also a complete portable compression system, coming with an inflation gun with 200psi air pressure guage, a 25' extension hose.
VIAIR Heavy Duty On Board Air System ( 35" Tires )
Heavy Duty Onboard Air System is a pre-packaged compressed air solution that provides a 33% duty cycle 400C compressor, 2.5 gallon air tank, and all components needed to install basic vehicle-based pneumatics.
Constant Duty On Board Air ( 37" Tires )
Constant Duty Onboard Air System is a pre-packaged compressed air solution that provides a 100% duty cycle 450C compressor, 2.5 gallon air tank, and all components needed to install a working system capable of inflating tires.
Air Compressors are in stock and ready to ship!!!!
Call the store and ask for a quote!
(909) 599-2228
info@lge-cts.com
Ask for John
(909) 599-2228
info@lge-cts.com
Ask for John
