X Dana 35 swap to Dana 44
the first run or two of 07 JKs that were on the lots in 06 had the D35. i think build dates after Nov 06 had switched over to the D44 rear. 07 models hit the show rooms around Aug of 06.
RebelMudHound has a D35 in his 07 JK and the spider gears shreaded this past weekend at Long's
I believe If you use the mopar axle its a direct drop in,, The calipers are the same and I think the new axle comes with rotors? For the $ its a good deal,, $1400? I'd switch out shafts to the better shafts while your in there tho.. I'm waiting on paperwork to get my 08(had an 07 2dr) and I'm thinking about doing the front 44 swap with a gear change to 4.88's.
If your swapin axles you could always do a pair,, regear and step up tire size while your at it..
Its so easy to spend other peoples money!
Steve
Steve
