35-12.5-17 on stock rim 17-7.5.
Old Jul 1, 2018 | 04:04 AM
1 Fantasy's Avatar
Default 35-12.5-17 on stock rim 17-7.5.
I have a 2014 Rubicon unlimited, want to run 35-12.5-17 on stock 17x7.5” rim, if I install a 1.25”BL and 1.5” spacer, would I have any tires rubbing problem?, mostly highways run with few light off road, also if I install a 2.5”SP lift, does that affect the angle of both drive axles any, and if it does, what’s the remedy? I am new on this Jeep thing and would appreciate any input, advice. Thanks.
Old Jul 1, 2018 | 01:16 PM
OH9JK's Avatar
JK-Forum Ambassador
You will want 1.5" wheel spacers for sure (Spidertrax or something comparable) and instead of a body lift I would look at a suspension lift. Not sure of your budget...a simple budget boost will allow you to run the 35's
Old Jul 2, 2018 | 05:20 AM
Wuebben.2's Avatar
I run 35x12.50's on stock rims with 1.25 inch wheel spacers and no lift. I had stock fenders for a while but under full articulation in the the trail they would rub and pop off, now I run the cheapo steel flat fenders. I tried fenderless too but didn't like the look as well as I thought I would...but that might not be an option in your state
