Doh!
Old Apr 2, 2008 | 09:15 AM
j&k'sjk's Avatar
Default Doh!
So yesterday I go
wheelin and it's the 1st time i've been off road with
the rear swaybar disco'd. I put the front of the
jeep on this little mound and get out to take a photo
and I figure while i'm out i'll take a look at the travel
on the rear. Glad I did. The brake line was stretched
pretty tight. Guess I will be modifying the bracket to
gain some extra travel in the line. Eventually I
will install longer brake lines but not right now.
Old Apr 2, 2008 | 11:12 AM
Dante's Avatar
How does it handle on road with the rear sway bar disconnected?
Old Apr 2, 2008 | 11:29 AM
Rubicon Rando's Avatar
do you really need to disco the rear? i have never disco'd the rear and stuffed it plenty, and yes i had to add extended brakelines and drop brackets
ID:	7632   Click image for larger version
Name:	poser 8 edit.JPG
Old Apr 2, 2008 | 02:48 PM
dpoelstra's Avatar
me too...
Most advise against the rear disconnect. With the front disconnected I had to lengthen the brake lines in the rear.
Old Apr 2, 2008 | 06:12 PM
j&k'sjk's Avatar
Because i am not locked in the front and I have LSD on the rear I want to keep the rear tires on the ground as much as possible. In the video below you can see that I have hardly any flex on the rear without disco.
http://www.youtube.com/watch?v=eDNFJAgGpDk
