Frame mounted Rock Rails
I drilled the rails for 4 bolts per mount but only used 3. I can jump up and down on them and they dont budge. I am not little either. (200 lbs) The high lift will lift the Jeep with these. We just used some flat plate to make the mounts. P.S. dont look at the factory pizza cutters. I havent had time to get the Iroks mounted yet.
I made some Shrockworks look-alikes but gave up on trying to make them removeable. I wanted to copt their brackets, but it was gonna be more trouble than it was worth to me. Mine are just welded to the frame. I guess they are still removeble, you'll just need a sawzall or torch!
A few pics (sorry, none of how they're mounted).
Yeah I just tapped the frame holes. Used red lock tite and lock washers on the bolts. The frame is I think 3/16 right there but could be thicker on the back mount. I know I went through about 12 drill bits when it was all done.
I have had the Jeep resting on one side rail before and it didnt budge so I must have done something right. I wanted them welded but my buddy didnt feel comfortable welding with the plastic gas tank right by the mount.
So no bolts on the other side then right? Nice....I will pass that on to him...thanks a lot
