Pinion bearing part numbers? D30 & D44
Old Sep 4, 2018 | 03:32 PM
lucky5's Avatar
Default Pinion bearing part numbers? D30 & D44
I am planning on doing a gear swap in the coming weeks and I'm trying to find out what the part numbers are for the pinion bearing. I ordered a E locker for the front and minor install kits because I didn't need the carrier bearings and it seemed to be a waste of money. Does anyone have any old bearings they could look at and give me the numbers off of the bearing and races? For both the D30 front and D44 rear. Also the bearings and race for the carrier on the D44. I probably should have ordered the master kit for the rear. I've looked online and can't find a clear answer, I keep getting different numbers.This is a 2012 JKU Sahara.Thanks in advance for the help.
