Stock Subwoofer replacement
Old Sep 26, 2019 | 12:45 PM
nick160225's Avatar
Default Stock Subwoofer replacement
So today I disconnected the subwoofer in the Jeep b/c it just rattles the trim pieces around it. When I was removing it I noticed that the box that it is in is pretty roomy and would make for a great little storage compartment for a tow strap. I considered adding a hinge and a locking mechanism to the subwoofer cover to act as a little door. Has anyone else considered this??
Old Sep 26, 2019 | 04:50 PM
L2R's Avatar
L2R
No reason you can't do it.
Sounds like a good hiding spot if you make it look stock.
good luck
Old Sep 27, 2019 | 09:35 PM
jordy's Avatar
Loved
Community Favorite
I threw an 8" dual voice coil Polk into the factory housing, with an amp that would carry a 2 ohm load for the sub, and put the factory cover back on. Sounds great, looks factory, with no rattle. I did also upgrade the factory amp to something a little more substantial, with an aftermarket head unit.
Old Sep 28, 2019 | 06:06 AM
crosstowne's Avatar
Default Subwoofer Replacement
I tried the Polk subwoofer with the original Infinity amp and it's 4 ohm resistance lowered it's output relative to the other speakers.
I tried the Quadratec direct replacement and after a little break-in I think its a great improvement.
Old Sep 28, 2019 | 08:48 AM
jordy's Avatar
Loved
Community Favorite
The factory amp is junk. I threw a 5 channel in and had previously upgraded all the other speakers as well. It's kind of obnoxious now, but the mirrors will shake when it's cranked up.
