JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Winch weight?
Old Nov 5, 2019 | 03:13 AM
Jim Martin's Avatar
Default Winch weight?
How much does your winch weigh? Looking to buy a winch for my JKU and just wondering if there's a light weight winch out there? Most seem to weigh about 90lbs.
Old Nov 5, 2019 | 03:24 AM
jadmt's Avatar
JK-Forum Ambassador
Warn vr series with synthetic is under 70lbs.
Old Nov 5, 2019 | 04:22 AM
Jim Martin's Avatar
Just seen this one. Rugged Ridge 15100.21 Spartacus Performance Winch (Synthetic Rope, 12,500 lbs.) Says it's only 68lbs.
Old Nov 5, 2019 | 12:47 PM
resharp001's Avatar
Loved
Community Favorite
If you feel you need a winch, who cares what it weighs. Look what you'll be asking that piece of equipment to do.
Old Nov 5, 2019 | 03:27 PM
karls10jk's Avatar
Just as you wouldn't judge a book by its cover, I wouldn't judge the winch by the weight. You'll find cheap Chinese winches as well as quality alloy pieces that will end up weighing the same. My winch is heavy, but it does everything I ask for. With a quality lift, I was not concerned about any height loss.
Old Nov 5, 2019 | 05:30 PM
Mr.T's Avatar
Community Favorite
67 lbs -- SW 9K Talon w/ synthetic line. Synthetic line saves about 20 pounds and handling it is easier.
Old Nov 6, 2019 | 05:39 AM
Dat's Avatar
Dat
I have a Ramsey rep 9000 that is probably pushing 100 pounds, it's probably 25 years old and has never failed yet, I have thought about replacing the solenoids just in case, but it keeps on working
Old Nov 6, 2019 | 04:02 PM
tjkamp's Avatar
My Warn VR-10,000 with steel cable weighs in at 98lbs. It's been going strong for about 5 years now.
A better way to go about picking a winch is to get one that has the pulling force and the features you want, and if it is heavier than you would like, consider getting the same winch but with synthetic line to make it lighter. With winches light weight generally means either very cheep, or very expensive.
As mentioned above, with a quality lift you won't get that much sag, and the first time it saves your butt, or pulls an otherwise immovable vehicle or object, you won't care how long you have been lugging that 100lbs. Chunk of steel around on you bumper. One necessary use of the winch will more than make up for the loss of gas mileage for a slightly heavier winch.
