Radio install problem
Old Nov 13, 2019 | 12:01 PM
Dinky Dau's Avatar
Veteran: Coast Guard
Default Radio install problem
I finally got around to updating the new radio. I had to pick it up after hrs. I have a big problem with the USB plug in and was told later they can't do it..I Say BS,,,,, The installed a cord with a USB connector with a lead that comes out the bottom of the dash...Why the Hell is their not a plug? They could hooked up to one of my cig lighter in the dash??It bites when you live in the mountains and have to drive so far to get anything done!! Isn't their a way? It's not rocket science! Any help would be highly appreciated! This really has me pissed off..
Old Nov 14, 2019 | 02:37 AM
karls10jk's Avatar
There is a way. Pull out the lower trim piece down by the shifter, pull off the top piece by the dash. This will expose some bolts. Remove the bolts and give the vents a twist, they'll come out. Then pull (gently but firmly) towards the top and bottom of the center dash piece. The whole thing will start coming forward but your AC things are still hooked up and the item between your vents will need to be watched. Once you've got that set then you should be able to run the cord where you'd like to and if you need to dremel out a corner for the cord, so be it. I think I'd prefer a longer cord to go to either the glovebox (my last jeep had an iPod that lived in the glovebox) or down across and to the center console (I frequently set my phone by the parking brake because it's too big with a case to go in the cup holder).
My directions are spot on but tough to follow with just words. I'd suggest you check out Quadratec or Crutchfield for their radio install guides and you should be able to get pictures to go with it.....or even the YouTube maybe.
Old Nov 14, 2019 | 04:08 AM
Dinky Dau's Avatar
Thanks I will go to the site and check...
Old Nov 14, 2019 | 04:43 AM
karls10jk's Avatar
Go figure I can't find the instructions on either site at the moment but I know both offer it. Crutchfield has free lifetime support and Qtec has instructions somewhere because I have a copy of them printed out in my cabinet somewhere.
Old Nov 14, 2019 | 04:45 AM
Dinky Dau's Avatar
Thank You I am in no hurry.
Old Nov 14, 2019 | 05:30 AM
karls10jk's Avatar
You've got mail!
Old Nov 14, 2019 | 08:26 AM
Dinky Dau's Avatar
You've got mail!
Got it thanks!
