DIY: Heater Core Flush with Filter Installed
Old Nov 18, 2019 | 04:53 AM
Dirt Hammer's Avatar
Default DIY: Heater Core Flush with Filter Installed
I know this topic has probably been beat to death here but I wanted to show people how easy it is to perform yourself and how to install an affordable filter screen.
Old Nov 21, 2019 | 06:35 AM
ArmyofMike's Avatar
Good video, Is your heater working again after doing this?
Mine had the same amount of debris when I flushed it, but still didn't alleviate the heater issue (on driver side). What did help immensely was switching the inlet/outlet heater hoses at those same clamps....Now, I have heat again.
Old Nov 21, 2019 | 06:41 AM
Yes heat (hot) returned but I think I have a blend door issue. Sounds like you just back flushed yours by switching the lines.
Old Nov 21, 2019 | 06:46 AM
ArmyofMike's Avatar
I flushed mine by running water through the outlet for 15min, added 4oz of CLR to inlet, flushed outlet again for 15min.... Then, I switched the lines after that didn't work.
Old Nov 21, 2019 | 06:50 AM
Water flows great through the heater core now, just getting intermittent heat on driver side.
Old Nov 21, 2019 | 05:39 PM
Bora Boy's Avatar
Would be good to add a step after flushing to blow out the lines. You can get a cheap hose inlet fitting for RV winterizing that you can connect a compressor to. That way zero tap water is left in the system🤞
Old Dec 9, 2019 | 05:04 AM
I got a ton of water out of it just by blowing it through with my mouth, but yes getting that tap water out is a must.
Update: Here's a video of me flushing the filter system I installed on the heater core inlet side.
Old Jan 18, 2021 | 02:57 PM
Mike Volk's Avatar
@Dirt Hammer If you are still here. Just wondering how this worked out and if you are still using it?
