OME 2" lift with Full Traction adjustable trac bars....3 weeks after, getting a nasty
Old Apr 5, 2008 | 08:51 PM
Area-51's Avatar
Default OME 2" lift with Full Traction adjustable trac bars....3 weeks after, getting a nasty
metallic sound (not sure it is indeed metal on metal, but it sounds like it) when going over bumps, or even accelerating from a stop at some points....the sound when going over bumps are much louder, but can still have it happen on acceleration from a stop as well.
Have done the cursory inspection, and not seeing anything busted, or loose, and can see no indication that anything is actually making contact on something else.
Ideas on what to look for? Have an appointment with the shop that installed it on Monday...
Old Apr 5, 2008 | 09:02 PM
nukeman's Avatar
My guess would be it's your Full Traction tracbars making their famous noise. Mine did it too. I would check the torque on the frame ends of both the front and back. The Vectron bushings and interal metal bushing sleeves like to make noise, sounds like a metal/metal, popping, grinding noise. You may have to increase the torque beyond what FT recommends, I did and mine haven't made a noise since.
Old Apr 5, 2008 | 09:03 PM
derekls's Avatar
I would defiantly take it back to the shop that installed
but it sounds like it could be a wrongly seated coil or busted shock?
Old Apr 5, 2008 | 11:33 PM
Ctimrun's Avatar
I am betting it is the track bars as well. It is a well documented noise (Don't know if I would call it a problem) with the Full Traction track bars. Torque them a bit higher and the noise will probably go away and stay away.
EDIT: It couldn't hurt to put a generous amount of grease on the bushings as well.
Old Apr 6, 2008 | 12:55 AM
Rubimon's Avatar
X3 125lbs means crank the sh*t out of them!
Old Apr 6, 2008 | 08:53 AM
bly109's Avatar
I actually had to pry my axle mount apart to get the FT trackbar in. So 125 worked for me. It seems like everybody's mount is different. I know one guy on here had to crank it to 175 to get the mount to sqeeze the bushing.
I also greased the shit outa it and put a zerk on it. So far not problems.
Old Apr 6, 2008 | 01:53 PM
Rebel Heart's Avatar
Are there other adjustable track bars that you would suggest other than FTs? I am also considering the OME lift with FT adj. track bars.
Old Apr 6, 2008 | 03:20 PM
Rubimon's Avatar
I have the Full Traction bars, so they are the only ones I can recommend!
Old Apr 6, 2008 | 07:00 PM
Area-51's Avatar
Thanks for the thoughts on it.
Old Apr 6, 2008 | 07:20 PM
nukeman's Avatar
That would be me. I tried increasing the torque in 10lb. increments. Finally, got to 175 ft. lbs and, with a ton of lithium grease, have had no noises for 3 months. I wouldn't recommend just torquing them to 175, I would increase the torque until you find the sweet spot, just use a lot of lube, um, grease, and she should quiet down.
