Rear Back up Camera failure
Old Jan 5, 2020 | 03:27 AM
sullivan9162's Avatar
Default Rear Back up Camera failure
I installed an after market rear bac up camera right after taking delivery of my 2016 JKU Rubicon. Has worked flawlessly since then. Starting several days ago when shifting into reverse I get a black screen and the "check surroundings" message at top of screen. Anyone have any ideas as to where to start looking for problem?
Old Jan 5, 2020 | 03:56 AM
Dinky Dau's Avatar
Veteran: Coast Guard
Mine is doing the same thing, it shows the lineup lines rest is black..I noticed the other day, that if I wiggle the the gear select a little, it starts to work. I planed on doing research as soon as some higher priorities are handled.
Old Jan 5, 2020 | 12:11 PM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
Sorry to hijack a bit but are these systems standalone or can one use the factory Nav screen as the camera display?
Old Jan 6, 2020 | 03:02 AM
Uses factory NAV screen on the dash.
Old Jan 6, 2020 | 07:26 AM
Ghost JK's Avatar
5 Year Member
Most times when it's just a black screen it's that the camera is not getting power, or the video line is pinched/broken.
Old Feb 7, 2020 | 09:10 AM
KG6SLC's Avatar
Default Backup camera failure
Ghost JK nailed it. Mine was working flawlessly for years...and then it wasn't.
In my case I found broken power feed wires in the transition to the tailgate that fed the camera.
I got the same check surroundings message on the screen that was otherwise black.
KG6SLC aka Eugene
Old Feb 11, 2020 | 11:00 AM
bwatson1982's Avatar
I have a black screen, but the grid lines and warning message to use mirrors in addition to the camera still comes up. Also, sometimes the camera works. Would this be a power issue?
Old Feb 11, 2020 | 12:57 PM
Ghost JK's Avatar
5 Year Member
Sounds like an intermittent power issue. Possible a pinched or frayed wire.
Old Feb 12, 2020 | 06:44 AM
any4xx's Avatar
I’ve gone through a few of the cheap bullet backup cameras. I’ve discovered that if they ever get below freezing they die. I figured for $19.00 I could replace them cheaply enough. But now I have a higher quality camera on my shelf waiting for the next failure.
Old Mar 2, 2020 | 02:30 PM
jdinny's Avatar
Loved
Community Favorite
From: up in the woods, on the back side of a mountain
Check power, and ground wire connections first.
