Jk Pinion Preload Torque
Old Jan 11, 2020 | 08:31 PM
Chessmaster's Avatar
Default Jk Pinion Preload Torque
Hi all,
I’m in the process of building a Dana 44 HD with J8 tubes. I decided to go with 4.56 gears from Yukon and a RD157 Arb locker. I have the pinion gear assembled into the housing and after several attempts I have gotten the pinion preload to be 20-22 inch lbs of torque. This is using all new bearings and the pinion seal is not yet installed. I am using a solid spacer and shim stacks to set preload. I’m not going the crush sleeve route.
I have a couple questions about pinion preload:
1) being on the low end of the torque like I am will this noticeably effect pinion bearing life? Yukon recommends 22-35 inch lbs and Dana recommends 20-40 inch lbs.
2) would it be worth taking apart again and trying to get closer in the middle of the pinion torque tolerance?
3) when measuring the pinion preload is that with the pinion seal installed? Does that add any additional pinion preload torque?
thanks for all the help in advanced.
Old Jan 12, 2020 | 03:57 AM
murdoc319's Avatar
I’m in the middle of a pinion preload debate on my own Jeep so I can appreciate the stress! I also have never done what you’ve done so take that into consideration..
I understand true pinion preload to just be the torque needed to rotate the pinion on it’s bearings with the seal and nut installed. I would suspect that if you’re already at around 22 in lbs without the seal and nut that your preload will increase as you tighten the nut and you can tighten to reach more of a mid range pre load
just my hypothetical thoughts without experience- not sure how not using the crush sleeve works here
Old Jan 12, 2020 | 05:12 AM
scubatech's Avatar
!)I would say no since you are within spec. You have no play in the bearing.
2) I wouldn't.
3) Put the seal in last and re torque.
Old Jan 12, 2020 | 06:03 AM
the nut is already tightened to the required torque so that will not add any additional preload to the bearings. I don’t have the seal installed yet so I am wondering if the seal will add additional drag once installed.
Old Jan 12, 2020 | 06:05 AM
2) I wouldn't.
for item number 3, does the seal add any additional drag, which increase the pinion preload torque measurement?
Old Jan 12, 2020 | 06:12 AM
ronjenx's Avatar
This is from a Dana Manual: NOTE: NEW PINION SEAL WILL ADD 3 LB-IN (.34 Nm) TO THE TOTAL TORQUE TO ROTATE
Old Jan 12, 2020 | 06:53 AM
awesome! thank you! So if I’m sitting at 20-22 inlbs without the seal, theoretically I will be at 23-25 inlbs once the seal is installed for the pinion preload?
Old Jan 12, 2020 | 07:25 AM
ronjenx's Avatar
Yes, but the bearing preload will still be 20-22 in/lbs.
Old Jan 12, 2020 | 02:40 PM
thanks for clarifying that. If it was up to you, would go back and try to get it closer to nominal pinion preload torque (30 inlbs)? Or just call it good?
