Slider or Step
Old Feb 22, 2020 | 01:15 PM
hinmo's Avatar
Default Slider or Step
Just took off my good looking sliders (or steps) that were attached to the body panel under the door and the tub/body sub-frame of my 07JK. They had caused minor damage to both the body panel and body subframe (rust didnt help on the subframe either). Took them off, and it looks ok, but would'nt mind covering the gap that exposes the frame with something that attached directly to the frame....eg. rock slider?
Whats an inexpensive pair that attaches to the frame and has a little strength? Pretty confused with all the options
Thanks
Old Feb 22, 2020 | 04:32 PM
hornetman's Avatar
Veteran: Navy
I did some bolt on ACE sliders and Warrior skins on the rocker panels
Old Feb 23, 2020 | 11:38 AM
tjkamp's Avatar
I have a set from White Knuckle Off-road, and am super pleased. They bolt directly to the frame, and can then be welded. Made to order, super strong, and function as a step as well.
https://white-knuckleoffroad.com/jeep-jk/
Old Feb 23, 2020 | 02:00 PM
hinmo's Avatar
Thanks folks - all good tips - will investigate both
