Metalcloak won’t give up their spring rates
Spring rates.
Last edited by donjuan79; May 1, 2020 at 09:15 AM. Reason: Editing because it won't let me delete it. I would think we could delete posts if we wanted to.
The metal cloak is a dual rate as the top portion does expand on its own. This allows for a longer coil length that won't drop out when using long travel shocks. It is true that you are only using a single rate most of the time. You can not get the length out of a progressive spring unless you were running a very low coil rate. Most companies will not tell you what the spring rate actually is but you will find most are in the +-230lb range. IF you use the JKS coils with the Rocksport or OME shocks that are long travel you risk the coil coming unseated under full droop. The metal cloak coils and shocks ride very nice and I would keep run the pair without hesitation. I have have done several installs of Metal Cloak and my customers have been very satisfied with the ride.
