JK rear Dana 44 contact pattern
Old May 5, 2020 | 02:21 PM
jw1224's Avatar
Default JK rear Dana 44 contact pattern
Hello!
I’m looking for a little advice on my contact pattern. I think I have everything set up correctly with the exception of moving the carrier a tad to increase backlash by about .005”. I believe the pattern looks good for pinion depth but I’m hoping for verification from the greater minds here.
cheers
Joshua
Old May 5, 2020 | 02:33 PM
resharp001's Avatar
Loved
Community Favorite
You do realize that as you move the carrier to get your backlash where you want it, it's going to change the pattern a bit? Asking right now is premature.
Old May 7, 2020 | 05:46 PM
jw1224's Avatar
Default Final assembly
Pinion pre load is about 25 in/lbs
Backlash is set at .009 in.
Here is the pattern I’m showing now, how’s it look?
Old May 8, 2020 | 09:06 AM
resharp001's Avatar
Loved
Community Favorite
I think that looks ok, but I don't do this daily....only 2 times on my own junk. Maybe @TheDirtman will give you his opinion/confirmation to ease your mind.
