JK Off-Road 101Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Whos has installed coil overs with out the use of a car lift is it possible and did you use regular jack stands or have buy massive jack stands like a set of sunex jack stands from northen tool ?
You will need to jack the jeep up enough to get the fully extended shock in there. You can pull the tires off so you can droop the axle and make it easier.
