Front Bumper "Hoop" for Stock Bumpers
Old May 18, 2020 | 01:05 PM
Reddout99's Avatar
Default Front Bumper "Hoop" for Stock Bumpers
https://www.quadratec.com/p/mopar/bu...rd-rock-bumper
I am wondering if anyone has seen something like this that would work for those of us with plastic bumpers that are mounted to the steel frame rails.
Thanks
Old May 18, 2020 | 07:30 PM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
Get one bent up at your local fab shop using 2-1/2" Black Schedule 40 or 80 pipe, weld some 1/2" flat plates on the bottom (don't forget the drain holes) drill the mounting bolt holes then get it powder coated. Then set it on your stock bumper and drill away for mounting it. Use Cadmium plated bolts not the Chinese chrome ones.
Old May 20, 2020 | 02:07 PM
Kojack's Avatar
i had the mbrp on my 11. going with maximus 3 on my 14. lots of different options out there
Old May 20, 2020 | 02:53 PM
Reddout99's Avatar
Sorry, I'm not familiar with either of those. Do you have any pics?
Thanks
Old May 21, 2020 | 01:45 AM
Kojack's Avatar
Here is my gallery link at teraflex. You can see that I also added the VDP high clearance corners. Just so you know, there is about 250k in harsh salty winters on that bar hence the finish removal. In your neck of the woods you would probably not have to worry about the finsh at all.
https://teraflex.com/galleries/2011-...r-jk-unlimited
Here is the maximus 3 guard. This is what I am using this time around. With the same vdp corners.
Old May 26, 2020 | 06:44 AM
Reddout99's Avatar
Thanks, I appreciate the pics as a reference. The RR Bumper Hoop looks to be a larger diameter than the Maximus 3. Or is that just the pics?
