4.10 to 4.56 gearings
Old Jun 13, 2020 | 04:07 PM
Tariq Khalil's Avatar
Default 4.10 to 4.56 gearings
Hello I have 4.10 gearing and the ring should be 41 teeth and pinon 10 = 4.10 and 4.56 41 teeth ring and pinon 9 teeth so if I change only my 10 teeth pinion to 9 I should have 4.56 or I should replace the ring too anyone done it before?
Old Jun 13, 2020 | 04:19 PM
MikeRM's Avatar
Ring and pinion gears are matched sets. You can not change just the pinion.
Old Jun 13, 2020 | 05:22 PM
resharp001's Avatar
Loved
Community Favorite
Old Jun 14, 2020 | 05:16 PM
Dat's Avatar
Dat
Yep, different angles, different cuts on the gears, sounds like it would work just from the numbers, but there is a lot more to it.
Ring and pinion come in a matched set
