Wheel backspacing
Old Jun 21, 2020 | 09:36 AM
Gavin Danley's Avatar
Default Wheel backspacing
I have a JK you that has a 2 inch lift and is on 33 inch tires. I am planning on putting 35 X 12.5 tires on it with 17 X 8.5 wheels. A lot of the wheels I like have a 4.75 inch backspacing. Would this be a good backspacing or would I want a different backspacing to avoid rubbing issues?
Old Jun 21, 2020 | 11:34 AM
resharp001's Avatar
Loved
Community Favorite
4.75 will be fine. 4.5 is ideal, but you can get by with up to 5.2" sometimes. If you have any sort of rubbing, you can also add a washer or two to the steering stops, but you should be perfectly fine with 4.75" BS.
Old Jun 24, 2020 | 10:04 AM
  • alright thanks you
Old Jun 24, 2020 | 10:37 AM
TheDirtman's Avatar
35" tires vary in actual height and width, some will work and some will rub.
